Profec B Spec II -- power on/off?
Old 12-16-2006 | 12:34 AM
cb951's Avatar
cb951
Question Profec B Spec II -- power on/off?
Considering getting a Profec B Spec II and TiAl 38mm WG.
This is probably a dumb question, but...
The Profec has a power on/off switch. Is it necessary to turn it on manually every time the car is started, or will it turn on automatically when switched ignition power is applied when starting the car?
-Chris
'86 951
PCA since '93
60k, WFHG, Evo BV, K & N (stock box), 3" Fabspeed bypass & catback (about to install); need chips, gauges...
Old 12-16-2006 | 12:38 AM
The DareDevil's Avatar
The DareDevil
You need to splice it in to a switched power source. If it is correctly installed, it will turn on and off with the car.
A boost controller is no good if it's turned off
Quick Reply: Profec B Spec II -- power on/off?
