removing charcoal canister from fender
How should i go about removing this contraption? Can i just plug the hose that was leading to it or is there something more i need to do?
thanks!
thanks!
All the random crap around the diagnostic plug can be pulled out. Pull the large hoses running to it and to the hard line in the center of the engine bay. Put a filter on the hard line, pull everything else and delete the vacuum line.
ok, I'm still new to all of this, so what can i remove (in idiot terms)? and whats the diagnostic plug?
Herr Unmöglich
There is a blue line that runs from the charcoal canister up through the fender well, to a vacuum switch just next to the brake res... from that vacuum switch is a vac line that runs down to the throttle body. If your follow the lines from that switch you'll see that on the firewall the line switches from hard line to the soft line... this is where Mike would have you put a small filter on it. I had thought of putting the filter in the wheel well just minus the charcoal can, but for the cleanest engine bay, Mike has the answer.
The diag port is a small black circular port mounted on the same piece of metal, at least it was in my 87.
*stares like a deer in the headlights*
hmmm I think I'll take some more pictures.. so i know what the heck I'm doing...
Thanks for the help guys! (sorry I'm so dumb, but I've never messed with a cars vacume system before)
I just stuck a cheapy breather filter (ebay) on the same exposed hose you show in your picture Spaze. I'm sure it's not the best method, but it's one less thing to do at this stage in the game. When I yank the motor out down the line, I'll see about deleting unnecessary vacuum lines, etc.
Rocket Scientist
Just remove the large black diaghram thing and also the silver one. Remove the lines they are connected to. One will run to the intake, plug that one. Then follow the one line that goes along the fire wall. It will run all the way to almost where the DME harness goes into the car. Then it will turn down and go directly to under the car. It will follow under the car with the fuel lines and go all the way back to the tank. I removed the entire thing, cut it back at the tank, and put a filter on it back there. Done.
Hey;
The line that runs down under the floor is the vent for the fuel tank. 9Fitty1 has a better idea. Would you want gas fumes venting under the hood? If you have that line open under the fender well, those fumes will come right in the drivers window when you're on track.
