Sudden Power Loss under Load (boost?)
On a spirited run yesterday, my car started to generate a symptom of sudden power lost on acceleration. While accelerating under load, the engine would just die as if it shut down for a second. When I let up on the gas and accelerate slowly, power would come back. It would happen around 3k-4k range (the last few times that I noticed) and in most cases I was in 2nd or 3rd gear.
Any thoughts?
Any thoughts?
Might be the TPS. Check that guy out too. First check for clicking when opening the throttle, if that checks out, look at clarks-garage.com for the full on testing procedure. Good luck!
