944S - wiring at DME questions...
Going with the pack
is quite monotonous.
I'm trying to determine if something is supposed to plug into the white connector in the first pic.
In the second pic - the white/green wire - where does this go? Any ideas?
I am trying to troubleshoot a no power to fusebox for the fuel pump issue.
Also - the blue circle - I assume this is the wiring for the glovebox light that someone had a little trouble with?
I found on my 944 N/A that the tach plug from the DME was set up with an in-line 4 pin plug and a square pattern 4 pin plug from the Tach. I connected the WG and GW wires around the plugs and the tach started working. Simply Amazing, ain't it? My guess is that someoine replaced either the tach or the DME and the connection plugs didn't match (in-line 4 pin to square pattern 4 pin).
Don't know about the white plug.
TRENSTELLE ELEKTRONK is translated as ADDITIONAL ELECTRIC in my manual so I assume these numbers refer to the lead connections shown between the Tank and the ETACHO and above the ETACHO. Is that the question you asked?
