Harness mounting question: how to keep stock belts?
#31
Originally Posted by Techno Duck
If its a 6pt belt.. sandwich the bolt ends for the sub strap under the two front seat belt mounting points.
#32
Originally Posted by ubercooper
update: got belts, installed 2 on roll bar (the seem loose even though they are attached tightley) and the door side one. Im curious where to attach the sub belts? I'd rather not drill, but I will if I have to.
also: what should I do with the 2ft of extra belt on the roll bar, can I cut if off?
Seb
Seb
Second best method of attaching sub belts, is to mount them to the front seat mounting bolts, or even to the seat frame itself. I suppose tied for second place would be to mount the subs to eye bolts drilled through the floor and backed up with big-assed fender washers.
You mentioned the shoulder straps are loose, even though they are mounted tightly? Not sure what this means. The buckle should be as close to the bar as possible while still allowing the belt to rotate on the bar. Make sure to triple loop the belts through the buckle. You can cut off some of the excess belts, but make sure to leave some extra in case you change bar/cage or a shorter driver moves the seat forward and needs more belt. Roll up the belt ends and put a zip-tie through them to keep them from flapping around.
Lastly, have someone really familiar with safety systems examine your setup to be sure everything looks good.
#35
This is after I took my stock seats out and put sparcos in, but its the same idea. I got lazy and only installed the 4/6 points for now. The place where the lap belt and the seat belt anchor are is the same place that you should attach the sub belts.
I'll take some better pics later.
-Seb
-Seb
