DME temp sensor-WTB
Hey everybody, I've identified a crack in my oil temp sensor on the head (in between cyl 2 and 3, so I need to get a new one-anybody have one (that's turbocharged their car?) or have any idea on the price of a new one? I'll have to give sunset a buzz tomorrow... thanks!
the part number is 944.606.125.00 - found one on ebay for $31...
Steve
Steve
Doc-
I just checked the part number on mine-it's 964.624.110.00 - which pelican lists as a oil cooler temp switch for a 911-but from what I read it's a temp sensor? Which pelican has for 6.50-any ideas if the 944.606.125.00 will work? do you have the aluminum gasket too? Thanks!
Steve
Steve
Steve,
If it is for your 968, then you need the 944.606.125.00 I would imagine someone has plugged the wrong sensor in there at some point. The 911's use a similar sensor for the oil temp switch, but I don't know if they are compatable other than screwing in. I have plenty of the crush seals on hand as well.
Karl
Karl
