My 944S MAF conversion thread
I have been promising to post info about my MAF setup, but obtaining the parts that I ordered over a month ago has been a real hassle. But, I am finally starting to make progress.
Here is a list of parts I am will be using for this system: - Lindsey Racing ST1 MAF - pictured - Custom 2.5" throttle body to MAF meter SS intake piping - pictured - Custom 3" SS intake piping (to be used before the MAF) - not pictured - 2.5" to 3.5" silicone reducer, 2.5" straight coupler, 3" to 3.5" silicone reducer - Custom chip http://forums.rennlist.com/upload/maf_system.jpg The piping will be powder coated tomorrow, an after pic will be right here...... http://forums.rennlist.com/upload/p1060105.jpg The goal is to plumb the intake under the header panel, on this side....... http://forums.rennlist.com/upload/p1010091.jpg Currently, my custom intake runs on this side..... http://i12.tinypic.com/2dqk2md.jpg It will be about 2 weeks before I start testing this MAF setup, because I am still working on the 944SMAX performance chip. But any info and updates will be posted here. |
where did you get the silicone?
I am VERY interested in how this turns out, what about that whole new intake manifold that someone was producing for 16valve engines??? can someone link me to the site?
Wow, we're actually making some progress on upgrades for the "S"! Now if we can just get someone to properly design an affordable cat-back exhaust system....
So you're keeping the stock throttle body? I feel like I've seen posts about whether/how to switch it out with a wider one. I could be wrong. I'm assuming you are just working around your current set up to take pics and that you're not really going to be keeping the stock filter box. My guess is that the chip will not really be compatible with a custom grind on the cams(?). Mine are stock right now, but maybe someday.... Please do keep this thread updated. I'll also be checking back for it. Kurt '87 944S |
Great work, Jesse! It's awesome to see someone pursuing the ideas I had with my S back in the day! Makes me miss it even more...
So how does the AFM intake sound right now? Any noticeable torque loss? |
Wow, we're actually making some progress on upgrades for the "S"! Now if we can just get someone to properly design an affordable cat-back exhaust system.... So you're keeping the stock throttle body? I feel like I've seen posts about whether/how to switch it out with a wider one. I could be wrong My goals have been: free up the air intake - accomplished free up exhaust - accomplished convert to MAF - in progress Stronger ignition - deciding which ignition to use (AEM, MSD, etc.) 4 into 1 headers - next larger throttle body/ port matched intake - contemplating head work/cams - LAST I'm assuming you are just working around your current set up to take pics and that you're not really going to be keeping the stock filter box. My guess is that the chip will not really be compatible with a custom grind on the cams(?). i currently have just a cone on my afm (it came that way). but after hearing so many poor reviews i am going to build one like this and get a vented header panel. are you pretty happy with this setup? So how does the AFM intake sound right now? Any noticeable torque loss? |
New pic with my piping powder coated in the 1st post of the thread....... now for basically what this thing will look like.....
http://forums.rennlist.com/upload/p1060107.jpg http://forums.rennlist.com/upload/p1060108.jpg http://forums.rennlist.com/upload/p1060106.jpg for a little diagram..... http://forums.rennlist.com/upload/diagram.jpg |
Basically, I am trying for the same system as stock. Just, instead of plastic intake piping, i'm using SS. The MAF will be approx in the same spot as the AFM.
Can't wait until you put some dyno numbers so we all can see the performance improvement!
The MAXTRONIC and his new fancy wide band will make the MAF version of the 944SMAX chips go MUCH quicker. I'll be able to tune his car from here... :)
please, where did you get the maf sensor at? Is it even compatible with the S? I thought they were only built for the 951's.
It's been stated like 100 times that it's a Lindsey Racing MAF. The MAF will be compatible with the correct software (944SMAX MAF chip). If you don't receive the Lindsey Racing newsletter (you should sign up) they stated in this month's issue, that Russell will be working on a plug and play MAF conversion.
This is great, this is almost exactly what I've been looking to do, but various other car and non-car related projects have kept me from getting to it. What are the bungs for between the MAF and the throttle body? IAC? Haven't looked at it in a while, don't even remember them being there.
