Best way to cut two oval holes in nosepanel?
Set to Full-Auto
Title says it, I have access to:
Cut-off wheel
Plasma gun (Miller)
Crappy nibbler
All manner of files/dremel tools
I am building an airbox that will go under the NP, need to get some ventilation and I have always loved the look of the dual oval that alot of the 951 guys use.
Cut-off wheel
Plasma gun (Miller)
Crappy nibbler
Can't say that I've tried it a car but here at the metal fab shop we'll cut 2 holes with a hole saw and connect the dots between them. If you need the elongate the the holes we use a "cone rock". It fits an a grinder, just go down to a local welding shop and ask for one. I know these tools are'nt on the list you provided but there cheap to buy.
Set to Full-Auto
Well, I was going to put some weather stripping-type stuff to make a soft edge. Will a plasma cutter cut through paint, or does the metal have to be bare? I have the paint to re-paint it when I am done, but I really don't want to have to strip the stupid thing.
Set to Full-Auto
I will clean up the edge by hand, and then cover the sharp metal with a rubber weather stip. Talked to the bossman, he will do the cut with the plasma - but prefers the metal be bare, no biggie. We have a really nice sheetmetal hole puncher I will use to creat the radius's on the stencil. Should turn out great!
Set to Full-Auto
No, there will be a baffle in there to prevent rain from soaking the filter element. The airflow will have to make a 90 degree turn before entering the air filter.
