Every single cold start fails the first time... second time...
Lifetime Member
Lifetime Member
Fires right up. Any ideas?
Thanks,
Matt
89 944 NA, 3.0L 968 engine
Thanks,
Matt
I assume you get the tach bounce while cranking on that first attempt that fails?
While my crank sensor connections were iffy, I would get a no-start on the first try and then it would fire right up on the second try.
Just a different suggestion than the usual thats an easy check...
Lifetime Member
Lifetime Member
I haven't seen 30s since living in NC.
I will try the FPR thing. RE: crank sensor connections... not sure I'm familiar with where the "crank sensor" is located. Does it have another name?
Thanks,
Matt
Thanks,
Matt
