First post (plus pics!)
Are you certain that the repaint is Sapphire? A good friend of mine has an 83 that is Sapphire and it is definetly "bluer" than your car. Unless it is the lighting.
Search is your friend suspension mod suggestions, starting at around post 15 or so on that thread. There are probably other threads, too - just a sample of what you can find her
As for the tach... do any of your other gauges misbehave? e.g., gas tank not showing full after a fillup, oil pressure, etc.?
You tach shows 0 rpm, except in 4th at WOT?
Yup, check/clean grounds and fuses. http://www.clarks-garage.com/ for procedures
I'll be hopefully going through my car this winter - you must have something really loose or crudded up on the tach, though
