Removed AC... vaccuum line question
Herr Unmöglich
I'm in the final stages of getting my ride back on the road, and I have a question about vaccuum hose routing through the firewall.
Clark's garage does not have a vaccuum chart for the ventilation... so I ask the list:
Since I have removed the AC, what vaccuum lines can be removed through the firewall. There were two lines where the AC hard lines came through the firewall. Are these necessary? I assume the heater control valve still needs vaccuum as I have not removed my heater core.
I need to figure this out so I can install the new vaccuum line kit I just received from Lindsey. Thanks!
Herr Unmöglich
Jim, for now I'm going to be keeping the heater core. Since the car will be street legal and it is often very damp here in the PacNW, I want to retain defrost for those chilly mornings.
I am however skeptical that the current heater core is fully functional, as I noticed some fluid that seemed awfully close to AF in the padding and drivers floor area when I was stripping the car. I'll find out real soon when she hits the road again, hopefully next week.
If the heater core is shot, I will definitely find myself in a conundrum... I assume you ask as it has an effect on the vaccuum routing?
However, since you're keeping it street legal I can fully understand your wanting to keep the heat hooked up. As 35thslp said, just hook those two vac lines back onto the nipples on that firewall plate and you're all set.
If your heater core turns out to be bad, you can have mine cheap.
