My #2 piston. No questions this time. I promise.
Old 10-22-2006, 08:06 PM
Calmchaos
Calmchaos's Avatar
Default My #2 piston. No questions this time. I promise.
Heres the piston that has been causing me all this trouble
You can see in the first pic where the piston was tapping the head.
Took the head to the shop and he said it was fine... Go figure.
Old 10-23-2006, 02:43 PM
StoogeMoe
StoogeMoe's Avatar
I don't see any evidence of the piston hitting the head. How would that happen? Did you mean piston hitting the valves? Again I don't see evidence of that. The only thing I see is the piston skirt broken. That's bad. What did that do to your bore? Where'd the piece that broke off end up at?
____________________________________
1986 944 NA - Guards Red - 91k miles - minty
1983 944 NA - Platinum metallic - 4200 mi beginning a new life
1985.1 944 NA - Guards Red - donor car
1984 911 Carrera Coupe - Guards Red (gone, but not forgotten)
"If you're not living on the edge, you're not living"
Old 10-23-2006, 02:46 PM
tinman944
tinman944's Avatar
Moe is right...I would be looking for the piece of piston before I worry about anything else
Old 10-23-2006, 03:07 PM
FotoVeloce
FotoVeloce's Avatar
Default YIKES!
I didn't see anything on the top of the piston that indicated contact (and I've blown up more than my share of engines). That busted piston skirt scares the crap out of me. That looks like something came in contact there.. otherwise how in the world did that happen!?!? I'd be looking for that metal and having the bore mic'd. YIKES!
Old 10-23-2006, 04:00 PM
tinman944
tinman944's Avatar
To me it looks like that broke when the conecting rod hit it when it was out of the engine
Old 10-23-2006, 04:22 PM
FotoVeloce
FotoVeloce's Avatar
OK. I'd buy that for a dollar...
Old 10-23-2006, 04:47 PM
Calmchaos
Calmchaos's Avatar
Yeah thats what it looks like.
But we found the broken piece in the oil pan when we took that off before the pistons even came out.
And maybe I didnt take a good pic. But there is a spot where the carbon is cleaner on the top. And it corresponeded to a clean spot on the head. They got only close enough to clean the carbon off it seems.
And the piston hit the HEAD not the Valves.... Ill see if I can find a pic of the head before I took it to the shop.
Oh and the cylinder bores were all surprisingly just fine...
Old 10-23-2006, 04:58 PM
Calmchaos
Calmchaos's Avatar
ok here you can see the corresponding part of the head.
They had to have been making contact.
Old 10-23-2006, 04:59 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Wow, for the piston to come in contact with the head three had to be a huge play in the wrist pin. Can you feel the wrist pin being that loose in the connecting rod? I’m not familiar with your previous post but was the engine rattling or making weird noises?
Old 10-23-2006, 05:07 PM
Calmchaos
Calmchaos's Avatar
The wrist pins were checked at the shop and said to be within spec. I still won't be reusing it. And it didnt feel loose.
Yeah the engine was making a knock like a SOB. I should also mention that the bearing spun.
I didnt take a picture of that sadly... But both halves of the bearing were paper thin and fused together. Not to mention razer sharp. LOL.
Old 10-23-2006, 05:10 PM
Team SSR
Team SSR's Avatar
What did the rod bearings look like?
Old 10-23-2006, 05:15 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Well that certainly explains the extra play!!! lol I guess youforgot to mention this. Just get another used con rod with a piston then have the crank re ground and use an oversized bearing.
How long did the engine run after the bearings spun?
Old 10-23-2006, 05:19 PM
Calmchaos
Calmchaos's Avatar
It ran maybe 5-6 minutes?
Yeah the crank has already been fixed (It was also bent!! LOL)
And I have 3 pistons in the block... Ive been working on this rebuild since mid july. And it would be done right now if I had a replacement tolerance group 2 piston. Which I'm just going to try to buy from a dealer.
Old 10-23-2006, 05:20 PM
Legoland951
Legoland951's Avatar
For the piston to go so far up, his rod and bearings must be completely gone. With that much metal in the engine, I would look for another engine since you can find a good running complete engine for $400 to $500.
Old 10-23-2006, 05:30 PM
Team SSR
Team SSR's Avatar
I guess it took me 3 minutes to post my reply above...
The head probably is fine, but while you have it off, might as well touch up the seats and the ports.
Quick Reply: My #2 piston. No questions this time. I promise.
