Will 951 torsion bars fit in an early 944?
Set to Full-Auto
We are replacing them because the originals are "tweaked", probably from being overloaded......and a fellow member is being so gracious as to give the 951 ones to me.
Originally Posted by Dmitry S.
If you're going to go to the trouble of taking out the torsion bars, you'll probably want to get something beefier than 951 bars.
Originally Posted by BlueDog944
I'm starting the planning of upgrading the OEM suspension on my 84. What would you suggest. Car's main purpose in life will be a track/DE car, and if its drivable on the street too, that's a bonus.
You can put in 250lbs front springs big front sway bar and no rear bar (or small one). Make sure the rear is really low (maybe a bit *** down) and it should be fine.
Originally Posted by M758
30 mm.
Thanks,
Thank you.
Originally Posted by Legoland951
I agree if you are going to go through the trouble, get bigger ones than a 951 since some n/a have the same diameter as the 951 torsion bars.
Haven't autox'd it yet so I'm not sure how it handles. Good on the street. But you can only tell so much on the street..
Did a quick look-up on Paragon. Seems there's two 30mm t-bars. Solid and hollow. Sine the hollow one is a higher price, I'm guessing that is the more desirable one? Any one try both? Handling differences between the two, or is it just the weight to keep the car lighter?
