Sparco seat mounting - Is this safe?
Herr Unmöglich
Got a set of Sparco sliders today... Spent some time in the garage today working with various ways of configuring things.
I could bottom mount the seats directly to the sliders. However somewhere I swear I read that for racing purposes that side mounts were mandatory. Can't find any documentation of that anywhere at the moment though.
With that in mind I cobbled together the following setup of side mounts attached to sliders. Given that all the pieces in the setup are FIA certified and I use grade 8 fasteners, is this safe? Are the sliders intended for use with side mounts or only with direct bottom mounting? I hope to run until later this winter when I can do a proper floor mount plate... assuming that I can still squeeze in the car with all the extra vertical lift.
I'm withholding further photos until this task is complete... so help me out!
![](http://www.schwanks.com/944/Part8/images/img_3664.jpg)
![](http://www.schwanks.com/944/Part8/images/img_3665.jpg)
there is a tech/how to on paragons site. http://www.tech-session.com/kb/index..._v2&id=92&c=48 that is what we are supposed to do. they say there is an "easter egg" on our floor. the sparco sliders will use the factory holes. the covered hole has a bolt under the tin cover. carefully drill it out and there is a bolt.
i am toying with the idea of getting the sparco bottom mounts for my cobra/konig seats and using the sparco sliders. the other seats are soooooo comfortable, but not certified etc.
go to the racing section. Redlineman posted a link in the Y belt theread i started to schroths site with instructions on how to mount the sub belt.
Herr Unmöglich
Thanks for that link Tom... I've read it before, but with all of the different websites having their own howto sections, I sometimes forget what I've read and where. Sounds like I'm on the right track... need to stop at my local indy hardware store for some more 8mm fasteners at lunch today and I can finish the install tonite.
Went to Home Depot last night and their prices and selection on metric bolts are absolutely ridiculous. 59 cents for a single individually wrapped 8mm bolt, and a further .25 for the matching nut? No way. On top of that HD doesn't even maintain stock on metric stuff, some 3rd party comes in once a week to refill the drawers... they had maybe 2 or 3 of each bolt. What a crock. I can get bags full of nuts and bolts at the indy for like 4 bucks.
Thanks for the tips, things are coming together and I am getting jazzed more every day. Can't wait to get this bad boy back on the road!
I finally have a picture.
Here is my seat mount. I use standard sparco side mounts with bolts going through the floor backed up with these plates.
![](https://members.rennlist.com/m758/seatmounts.JPG)
The 4 gray plates at the corner are the seat mounts. The two goldish plates are from the Schoth sub belt mounting.
