Dripping oil... dip stick??
Well it seems to be leaking quite a bit. Not sure from where, but i noticed that after i reinstalled the turbo, i didnt reinstal the dip stick tube properly, well iput it in better the second time around BUT i couldnt get it perfect, some of the Oring is bulging out., Would much oil leak out of there??
any tips on how to seat it better?
See item #5:
http://www.lindseyracing.com/Merchan...NETRANSOILMISC
It's a plastic spacer ring that pushes down on the o-ring to keep it in place.
hmmmm, I dont remeber and plastic spacer like that. BUT, the tube end didnt look exaclty like that one either, it had a slight step on it where the oring sat, then the flange part. I was going to put a new oring on it, but the only one i had was a bit tight and would roll off.
