help
I have a 84 944
When i go to start the car it will start right up but the when i turn the key to run it will die right away. What is happing is the fuel pump turns off right the key turns back to run. Im not sure why it is doing this but i did cheek the fuel pump relay and it is working fine. So from what i can tell i think that it is the DME but i have no to test it. so does any one have any idea what it could be thanks for your help
