Torsen LSD or not? How to prove?
I bought a 968 that does not show code 220 for it being delivered with Torsen LSD...and when I jack up the rear, and turn one wheel, the other turns the opposite direction...just as some Torsen LSD owners have reported.
At the same time, in deep, soft gravel, when I dump the clutch at 4000 rpm, it doesn't sit around and spin one wheel but both spin straight on equally. It's a sight to behold.
Further, starting out in gravel and hitting the asphault with tires spinning like a bansee, it lays LONG EQUAL tire rubber marks in a straight line.
Further, starting out on asphault and dumping the clutch, it does the same...equal long rubber marks.
Short of trying it on ice and stepping outside the car and watching the wheels spin, I'm not sure how I can prove LSD one way or the other. Ideas?
I just want to know if a PO had it installed or not.
Harvey
Harvey
could be, particularly if at some point that tranny had to be rebuilt due to a pinion bearing issue that some had from the factory. not much help...
Hey Man
Originally Posted by tedwright
. . .then you do not have LSD.
I have heard of torsen diffs acting like open diffs when you do the jackstand test; however on my 968 which had LSD-- the wheels both spun in the same direction.
I wonder if it would be possible to unbolt the axles from each side of the tranny and measure the break-away torque from side to side??
My S2 does not have the LSD option code...but when I brought it to the wrench for it's initial tuneup post purchase....low and behold...it's got LSD. Guess it could have been a swap at some point....but it's there.
Down side is the LSD clutches are worn....another thing on the 'future to-do list' !
Apparently, there were two kinds of LSD built at the same time....and it's hard to tell which is which. One is Torsen and the other is the clutch type I think. If my car doesn't have LSD, then it certainly doesn't seem to need it in actual use. I'm very satisfied with the traction I'm getting.
Now, my 928 is a different matter. No LSD and one tire will smoke. That's really bad on the track, expecially when you unload weight off one tire in the corner and you look back and see a trail of smoke coming from the spinning tire.
Harvey
Harvey
Quit Smokin'
Harvey,
You should also check the transmission code... My 944 turbo does not have the LSD option code, but it does have a clutch type limited slip, and the transmission code is correct stating limited slip without a loop cooler.
Hey Man
Originally Posted by smokintr6
Harvey,
Quit Smokin'
My car is an '87, but it was not a standard item. 944 option stickers are starting to be known for being really inacurate. I have heard several stories of turbo S cars with all the "S" goodies, but none of the options listed in the back. My transmission code is "9U" which I understand was for the optional LSD with no cooler.
Hey Man
Originally Posted by billthe3
As for testing if its a limited slip, you could always try drifting. If its easy its a lsd, it its hard its not. lol
Originally Posted by KuHL 951
Stop making sense! Sorry I misssed the run today, sounds like it was a good piece of pavement.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Umm...
Why would you dump the clutch on gravel, and throw rocks on such a nice car? Thats what has ME baffled.
Bottom line, if you can leave two marks, you either have; lsd, locked, or spool. Period. Now go have fun with it, OFF the rocks!
Originally Posted by BigNNasty
Umm...
Bottom line, if you can leave two marks, you either have; lsd, locked, or spool. Period. Now go have fun with it, OFF the rocks!![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
