Plug firewall holes when removing AC?
Quick question this evening... finally pulled all the engine bay hard AC lines. What a PITA... ended up just cutting one of them into pieces, don't have a clue if it is even possible to remove without pulling the brake master.
Anyway, I left the heater core for now, so the coolant lines are still there. Do I need to plug the holes where the refrigerant lines pass through the firewall?
Anyone done this? What did you use, or does anyone have pics?
TIA
TIA
