Q: Turn-signal diagnostics.
Hi
My turn signal just stopped working. Once th turn-signal is engaged the green light turns on in the instrument cluster and burns continiously. There is no light in actual signals and no action on relay.
The emegency switch works fine and all is ok with emergency signals on.
Anything similar happened to you with early 944 ? How did you fix it ?
Nerd Herder
Check for oxidation, and clean the ground bundles behind the headlight buckets- dielectric grease and reassemble.
Make sure the return tab on the steering wheel hub hasnt broken as well.
HTH
HTH
