Nova guys a favor?
Guys in the DC area. could i barrow a "cheesehead" socket from someone? I'm planning on removing the transmission sunday, and i dont have this very important little tool. There are some how-to's that say an 8mm allen will work??
thanks
-Spaze
thanks
-Spaze
Just be aware that "cheesehead" means the head is round and sorta thick, like a round of cheese.
Whether it takes an Allen, Torx, triple square or screwdriver is another issue.
8mm 12 point allen head socket
Thats what is used to get the axles off if I read correctly.
yes, that is the right tool, but i suggest you buy one if u plan on doing any other work on ur car, because you have to remove the tranny for a few other jobs like the clutch etc. they are cheap and shouldnt be hard to order and get to your place by mid next week.
I changed my clutch recently, and i attempted to use an allen wrench, but it stripped one of the bolt heads. luckily i had replacements and found an 8 mm 12 point.
Locally Pep Boys stocks a relatively inexpensive set. $15 or so, and you use them in a 1/2" socket. Call ahead though, when I wen tlooking for it the only one they had was opened and missing the 8mm (coincidentally what I needed)
