Turn Signals Won't Work
Old 09-29-2006 | 09:40 PM
arbeitm's Avatar
arbeitm
Default Turn Signals Won't Work
Each time I fix one thing...something else doesn't work.
As it says in the title...my turn signals don't work. I flick the lever up or down and nothing happens. The outsides and inside lights do not light up.
How do I fix this.
Old 09-29-2006 | 09:47 PM
Techno Duck's Avatar
Techno Duck
Check the turn signal relay.
A good test is to turn the hazards on, if the green light on the dash lights up solid..its the relay.
Old 09-29-2006 | 10:14 PM
arbeitm's Avatar
arbeitm
Ohh kaaaayyyyy.
I just tried the hazards and they work. So I went to try the turning signals...and now they work.
What's up with that???
Old 09-29-2006 | 10:46 PM
Rock's Avatar
Rock
Lazer Beam Shooter
The yellow car did this for some reason.
Something was up with the hazard switch, to where it would look like it were switched off, and the hazards would be off as well, but the turn signals wouldnt work!
I finally figured it out, i tapped on the hazard switch and voila! They worked!
Old 09-29-2006 | 10:55 PM
arbeitm's Avatar
arbeitm
Interesting. I did take the trim panel off the other day. I wonder if moving the hazard switch around did something. I'd have to check the diagrams to see if there is a connection there.
....I think I'll go relax and watch some TV instead.
Quick Reply: Turn Signals Won't Work
