You can get the 5th from a blown up 88 or any turbo trans, just swap it into any 944 trans. 4:11 can be sourced from an Audi but they're rare, or you could buy new too. Maybe Powerhaus?
Thanks a ton for the info. I will use mt turbo trans if neccessary for the short 5th. I still will look for an addional trans for my "other" project...
Yep most guys try to get a 924S (87 or 88) tranny or 88 944 unit for the short 5th. However a standard long 5th gearbox can have a short 5th installed into it. This gear comes in turbo all years so if you have broken or spare turbo tranny and a long 5th NA gear box just use the 5th from the turbo unit. It is pretty easy swap as gears go.
