will a 924 hood fit my 84 944
the PO tried to close the hood except the hood struts were corroded so hood has a nice crease. i have located some hoods but the closest, cheapest, nicest is a 924 hood.
are they the same...rather are their differences in the hood between different models and years?
Originally Posted by sharky47
If it is an Audi-engined 924 hood, you will need to make/install the hood lift strut attach points.
The 931 hood can hit the wipers on the later cars but seems to fit the early 944 models fine. The wiper mounts are moved a bit on the later cars, something to do with the different windshields I think. You'll probably get a better reply from someone who has done it before. I almost bought a 931 hood for the 86 but the seller said that's why he was selling it; wouldn't fit his 86.
I have a 924 hood (with the prop) and it fits my late (85.5) 944 just fine, no problems. The back of the 924 hood is a little different, there are no indentions for where the washer arms go. The clearance is tight, but it fits provided you have it adjusted properly. FYI, early (83 and early 84) 944's have basically the same 924 hood, with the hood prop hole and flat back, and the hood shocks.
Originally Posted by Legoland951
Maybe in Europe, not in the U. S. as all 924s have rods unless they are 87+.
I'm not a fan of the prop rod, it tweeks the hood way too much.
