944 thermostat
It is located in the water pump (where the large water hose attaches). It is retained by a snap ring. There is a special tool to remove it, or use an angle-tipped snap ring pliers and some patience.
Sorry about the old bump but i'm doing this too..
so i just remove the big hose and it'll be accessible?
I was driving and outta nowhere my car had a bunch of steam out the back while climbing a hill, i let off for a bit and came to a red light no steam, then the temp gauge was maxed so i quickly pulled over and then steam came out of the hood i'm guessing it's the thermostat?
And what oil should i run during the winter? i'm using 20-50 but it's getting below zero at night, i worry that it's too thick (166XXX kms on car)
^it was kind of more steam across the back of the whole car and very thin not thick white smoke like a head gasket.. i think it was coolant leaking onto the exhaust.. the oil was fine no coffee likeness heh.
I got the hose off.. it's impossible to get at the c-clip holding the thermostat in. Do you go from the top or bottom or what? I don't have the special pliers from porsche (i can't drive anywhere).
I just have some c-clip pliers that are right angle bent, and a pair with a very slight bend (pretty much straight)
ps: it's raining outside, i'm in a carport... coolant has run down my arm and splashed my face.. i'm cold, wet, and have class at 7pm.... God help me haha.
Its hard to get the thermostat out. Keep working at it and eventually you will get it. I have done 3 of them and never really came up with a good method yet other than when getting one corner of the snap ring out of the groove, keep it out and work the rest out of the groove slowly. I have never gotten the whole thing loose and pulled directly out in one shot. Also I broke a snap ring in half once so be careful with that.
^oh ok, well everyone was tellin me it's the thermostat.. the engine was over heating before the rad was getting warm.
so i should hold the lower rad hose to see if it's hot, not the top one? :P uh oh i may be a moron
Oh and i didn't think it was a leak just because i couldn't find the leak anywhere i know it has to be leaking somewhere but i'm not sure where... i added water to the system and let it idle all that i saw was the car getting hot and very very little steam coming up near the intake manifold
Sorry to keep bumping this but i have an update
Lower rad hose stays stone cold, upper rad hose gets hot (the big hose) car over heats and the coolant stays stone cold as well. looks like i'm missing class tonight ohhh man.
