A/C delete belt info
Alright guys, i installed an aftermarket A/C delete over the weekend and me being the smart guy i am, but all done and realized i dont have a belt for it... oops! I called my local autoparts store gave them the year, and belt type, and asked if they had one shorter. He did everything he could to not laugh, nor did he have any info on where i could get one.
So i come to the people that i should have asked first
Its a 84, so i have the 5 "ribbed" belts. I did a quick string measurement to the tune of 26 inches. Now, do you all know where i could get belts like this?
thanks!
thanks!
gates K050330 belt. 5 ribed and everything. Worked for me ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
https://rennlist.com/forums/showthre...elt+alternator
Location: San Francisco, CA Porsche: '92 968 Blk/Cashmere
Mine is a 6-rib, but the length should be close to the same if not exactly the same as yours.
conti-v multirib 6 PK 720mm
conti site
conti site
Alright, so I tried the K050330, the K050316 and neither fit. They were both too long
So I'm going to try the K050260. What do you all think? I know its a 5 rib belt and its about 26 inches long.
Originally Posted by Matt Marks
Ross,
You need a 1000mm belt for DD's kit. Gates should make an equivalent.
part number is K050280
Anything in the K0503* series was WAY to long, the alternater would hit the frame rail before it would get tension. After 3 off the shelf belts i ordered one and it came in today. Now all i need to do is pick up some hardware to mount the tensioner and I'm good.
I must have a weird car or something.. but i know I'll be carrying a spare belt where ever i go!
Thanks for all the help guys!
I would guess that as long as the belt doesn't "wobble" too much in the long spans, you're good.
I tried my ghetto AC delete the other night and the belt literally flew off the pulleys. Guess I shouldn't have cheaped out on the cool shiney bracket...
