Are the rear shocks really that easy to replace???
Just did this the other day. Definately use stands to give you good access to the top nut and bolt. Biggest trouble I had was breaking the bottom bolts free. I used my jacks' tubular steel lever over my rachet driver for a mother load of leverage which did the trick nicely. Remember to torque up real good when finished too. Good luck!
Pics:
Pics:
Unbannable
Wow, that was easy!
The only reason it took as long as it did was because I dropped one of the upper washers and spent a couple minutes looking for it. I think that was the hardest part of the job!
BB.
BB.
Defending the Border
Rest In Peace
Rest In Peace
Yep, as long as you dno't do it like Giantman!
Jack the car up enough to get your arm on the top, undo the bottom, then second guess what setting you want, presto!
Originally Posted by BeerBurner
Ha ha, no, it didn't take that long. I only consumed one beer in the process!
BB.
BB.
Hi Guys. Spurred on by your comments about how easy it is to change the rear shocks, I attempted this job at the weekend on my 924 2.0. The nuts came off eventually but the bolts just rotate and no sledgehammers will move them either. I presume the metal sleeve for the bush is seized on to the bolt thread. Anyone got any ideas on how to remove them? I'm thinking some kind of puller similar to a vice clamp. Help!!
Cheers
Alan
Cheers
Alan
