Intake Manifold Question
Old 09-08-2006 | 05:15 AM
Andial951's Avatar
Andial951
Legend Killer
Default Intake Manifold Question
I took my intake manifold off last weekend to do the venturi delete and I noticed the last bolt on the manifold (closest to firewall) was not an allen head bolt like the other 7 but instead just a regular bolt that was been used as a ground.
Is this normal?
Old 09-08-2006 | 05:35 AM
FRporscheman's Avatar
FRporscheman
Steve and I just took off his manifold Tuesday night, but he was doing all the wrenching. He mentioned some grounding cable back there, so I'm pretty sure that cable belongs there, but I know that bolt should also be an allen head bolt.
Old 09-08-2006 | 05:41 AM
Andial951's Avatar
Andial951
Legend Killer
Thanks Arash.....I saw a 944 engine at Parts Heaven today and the there was an allen head bolt there and it was not been used as a ground...but then I dont know if there was a difference between the 944 and 951 (yes yes I kow I should just go look at my 944 but its late now).......The bolt does tighten down so I think its OK but was just wondering if this was normal or not.
BTW - Venturi is out and car is running strong....and my brakes are back......
Old 09-08-2006 | 07:58 AM
KuHL 951's Avatar
KuHL 951
Hey Man
Originally Posted by Andial951
...BTW - Venturi is out and car is running strong....and my brakes are back......
It's amazing what losing 5' of old tubing will do. The venturi delete is one of the best things you can do the turbo to rid yourself of several nagging problems. Sorry you can make it Sunday, don't win too much at Tahoe!
Old 09-08-2006 | 12:55 PM
potent951turbo's Avatar
potent951turbo
iPod Tamer
I don't think that is normal. Originally there is a allen head bolt that holds a clamp for the engine harness snorkel. I would assume that someone couldn't get the ground put back on the bell housing and used the last bolt on the intake manifold instead.
Old 09-08-2006 | 01:29 PM
Andial951's Avatar
Andial951
Legend Killer
Yeah that Venturi is a mess.......The main tube that runs from the brake booster was cracked everywhere and several other tubes were suspect. I have more vacuum now and no brake issues. Its great. Heading to the dyno this morning before I leave to Tahoe.....
Here is a pic of some of the tubes I pulled out. Also removed the CV while I was in there.
This is that main line from the brake booster......it looks like soeone cut it in half but it was just brittle and cracking
the CV line
Old 09-08-2006 | 01:37 PM
hosrom_951's Avatar
hosrom_951
UAE Rennlist Ambassador
The intake manifold bolts should be M8 Allen.
Correct me if i am mistaken, but is that also a ground wire, attached to the harness bracket (where that hex-bolt is right now)?
If so, it wouldn't be like that.
Old 09-08-2006 | 01:49 PM
Crunky's Avatar
Crunky
Yah, I just looked on my N/A, they're all allen heads, and that isn't a ground on mine either, though it does hold down a bracket that supports the fuel injector wiring harness.
Old 09-08-2006 | 02:06 PM
iamgod's Avatar
iamgod
whats the inner diameter of the tubing
-edit- or rather the proper size tubing to replace it with?
Old 09-08-2006 | 02:23 PM
Techno Duck's Avatar
Techno Duck
Andial, what did you replace the larger line that comes off the brake booster with? That is the only vacuum line i have yet to replace. Cant find a part # for it in PET.
Old 09-08-2006 | 02:41 PM
Andial951's Avatar
Andial951
Legend Killer
I bought the LR venturi delete kit. Since I also removed the CV and those 3 hard tubes that are welded together I had to get a replacement line for the tube that runs from the AOS to the j-boot. I just picked that up at the parts store....its 5/8 heater hose.
Everything before I deleted it. Took out 1, 2 & 3. 1&2 are connected and part of the CV....3 is the venturi.
This is after the delete. The long tube in the middle is from the AOS to the j-boot which I had to get at a parts store. You cant see the long tube from the brake booster to the manifold in this picture but that line came in the kit.
Old 09-08-2006 | 07:21 PM
Tom M'Guinn's Avatar
Tom M'Guinn
All 8 should be allen heads -- at least on every 951 I've ever seen. That ground strap is supposed to attach to the bell housing. There is a picture on my site (link below).
Old 09-08-2006 | 08:47 PM
special tool's Avatar
special tool
That is very funny. I do the same exact thing to my cars - except I use pretty green wires.
It facilitates clutch changes.
I am sure Andial did it - its fine like that, trust me.
Old 09-08-2006 | 09:05 PM
hosrom_951's Avatar
hosrom_951
Andial, this is for you're 2.8L right? why are you running or still using the CV with what you got? you were able to get 13psi with teh CV still in?
Old 09-08-2006 | 09:24 PM
KuHL 951's Avatar
KuHL 951
Hey Man
He said he removed the CV with the venturi delete. I 'was' running 16 psi with the CV but the boost spikes were something else.
Quick Reply: Intake Manifold Question
