belt tensioner
I stripped my timing belt and broke an exhaust valve. This happened when I
starting it.The head is at the shop, I haven't heard from them yet. The pistons look fine no damage. I found that the nut had come off of the end of the
spring for the tensioner, the nut that holds pressure on the spring. Are there
any washers or just the nut on the end. This is on a 87 NA. Thanks.
Larry
Larry
