A/C ?? again
A/C ?? again
I find out now that my 89 S2 was converted to R134a. **** me off. It was blowing cold air a few weeks back but now when I turn on the A/C it blows warmer air than if I leave the switch off.
I checked coolant pressure and it appears to be good. The compressor turns on when I push the button. The fans had blown the fuse but when I replaced the fuse they worked fine. When I look at the sight glass I barely see any bubbles.
As far as I can tell the system should be working. Any thoughts? I am thinking a blockage in the system but not sure.
I wish they would have left it with R12 but too late for that now.
I just went through this in my S2 as well.
My compressor was kicking in properly but it was also leaking. Tried having it rebuilt and it lasted about 2 years. This year it started blowing hot air again and the dealer diagnosed a leaking compressor.
We gave in and put in a new compressor. Problem gone.
I really hope this isn't the case with your car, but if I had to do it all over again I would've saved the 800 Euro rebuild 2 years ago and just bought the new compressor back then.
Good luck!
Good luck!
Good luck!
Good luck!
I guess I need to get underneath and get a closer look. Maybe add some fluorescent dye and see if it shows a leak.
Yes, it would really be a bummer if your compressor was bad. I just replaced with OE and it probably cost more than the car is worth...
At any rate, in the U.S. you can fit a SANDEN compressor which should do the trick for A LOT less money. Just make sure the tensioner arm fits on square or you'll start going through accessory belts. HTH
