Urgent: need speed sensor OR DME!! in Atlanta
Anyone in the atlanta area have a speed flywheel sensor?
my car died today, and it will not start. When i crank it the tach does not bounce...
Did yous try jiggling the **** out of them. Tach not bouncing can also be a DME relay or DME
We had something funky like this happen on the yellow car. It just randomly didnt start for some weird *** reason, even though it had been running litearally 2 minutes prior. Dr Boost ended up holding the contacts on the DME relay and it started up!
Unplug and replug the connections. Worked on my car.
I ordered new ones after that. It's worth the extra measure of reliability. Add new gas lines to the mix, and maybe, just maybe, I can convince my parents to let me drive it to the fest next year (if there is one).
okay anyone in atlanta have an early car DME that i can borrow? I am going to to test the sensors now, to see if they are good... My car is stuck outside my house on the street, and I need it to get home.
I recently repaired my DME, Click on this thread.
My issue was that the car would randomly and suddenly die and then would not re-start. It would turn over fine, just wouldn't fire. I think the tach needle would move when I cranked it, although I don't recall for sure.
Anyway, hope that gets you going again.
okay, I followed the clarks garage directions and checked the resistance on the two sensors, everythign seemed fine, but the part that i don't understand is I am not getting any reading on the outside two pins on either sensor, can't explain that.... anyone?
Nevermind, my readings are within spec on the speed and ref sensors. Thank goodness i am not studying electrical engineering....
so could a bad DME cause the tach not to bounce when cranking the car?
May the force be with you.
