New crush washer for OPRV?
Originally Posted by sharky47
Well, if you do it with all the belts/waterpump off the whole job becomes way easier - don't even need to pull the PS pump if you go that route. Really, having the WP out made all the difference in the world.
Other than that, the OPRV and sending unit are screwed into the same peice of metal. Sending unit is just two wires and then the whole thing unscrews from the oil cooler housing. The OPRV is underneath a plug - 17 or 19mm IIRC, just falls right out. Check it for burrs or rough spots, reinstall - if you don't pull the oil cooler housing there is no reason to even think about having to align it.
Again, thanks a bunch everyone. My car would be a broken POS if it weren't for Rennlist.
