A/C Recharge car died (new info)
Originally Posted by josephsc
If it went to zero because you disconnected the jumper cable -- the problem probably lies right there. I'd bet your battery is dead -- how old is it? It's a super easy fix.
I typically don't like to mess with batteries - at the first sign of a problem, I just replace it. Costco and Sam's are great places to get replacements.
The question remains though - is it your battery or the alternator/regulator. If the battery won't hold a charge, (i.e, you charge it fully, come out two hours later and the voltage is down a couple of volts) it's toast. If the alternator won't charge, it's likely the regulator is toast.
A fully charged battery alone (no alternator) should be able to run the car for a few hours.
The wiper speed is a good indicator of alternator output - you should see a noticable increase in how fast they move when the car is running.
There is a rating on the battery, not cca, but another one i forget what the letters are... it is how many minutes it can run the car with no alternator and a full charge.
Battery was dead so brought it to Autozone who charged it and tested it and said it was good. Brought battery home put it in car and drove back to Autozone for them to check the alternator. They said the alternator was putting out 11.0 volts and 25.6 amps. Is this right? If not I need an alternator. If they are correct values what's next?
I also had them test it with the fuse to the a/c out and got the same values.
Alternator is bad. It could just be the regulator portion of it which can be replaced for cheap and isn't to hard to do (although you will need to access the back of the alternator).
Didn't they tell you that it's bad? -That alternator should put out 13-to-14 volts, and should be good for 90 amperes or so... Eleven volts and 25 Amps is mizz-err-ah-bull performance.
Keith
Keith
Dan, the place that rebuilt your starter can probably rebuild the alternator also.
I have a brand new voltage regulator, the part which wears out usually if you need it. Should not be to difficult to change it. It would require atleast removal of the AFM and the airbox.. not sure whatelse on your car.
I think the airbox, AFM and belt that needs to come off. If all goes well should be up and running by tomorrow afternoon. Then the big question.....
Should I continue charging the a/c system? I have another can and a half of r-134a to add. Did the drain from the compressor ruin the alternator? Now I am thinking that th e car might not have started as strong as it does when I pyulled it out of the garage to do the a/c. Wish I pay more attention.
Before you take the alternator out completley, unscrew the regulator (two screws) on the back of the alternator and check the brushes. They are spring loaded and will recess back into the regulator housing. If they dont stick out much anymore from the housing the regulator is probably shot. If the brushes still stick out.. the alternator itself probably needs a rebuild or should be replaced.
There is probably a cooling shround on the back side of the alternator.. its a pain in the *** to take out, but this needs to come off before you can access the alternator.
Its possible its just a coincedence that this happened the same time you charged the a/c. Who knows. Ill be around tomorrow.. in Freeport from 1-6pm about. Ill be home from then on (or probably hanging out at Bagel Boss). Call my cell if you need it... ill leave it in the glove box so i have it on hand.
