suspension question(s)
Ok my shock/spring swap should be finished up this weekend. When I took the old struts out one of th e bumpstops has almost competely deteriorated. I was lookign on paragon and they have the original stops and then koni "competition" stops. Is there any benefit with the koni stuff? Thanks!!
Yeah, you get to say you have Koni stops.
Just kidding. They are shorter and use a different compound so they act as a bit of a spring when you get down to the bump stops. IIRC though, it is hard to use the dust covers with them since there is no provision to attach the cover to the stop like on the stock stops.
