Any other '83s on original clutches?
I'm starting to wonder if I have the oldest (actively running) 944 remaining with its original clutch. Build date 2/83 and the clutch is fine. Anybody else have an '83 with the original clutch?
Now watch it disintegrate in a week.
83 right here with the original clutch, not sure of the build date, i think 6//83 but not sure at all. But yea i'm starting to feel it, and plus the odo stoped working at 54,000 so who knows how many miles are on that thing hahahaha
You have a rubber centered clutch. If the rubber center starts falling apart (becomes brittle/crappy over age) you get this real bad drivetrain lash when you get on/off the gas. The clutch is probably only on its metal tabs at that point and s hould be replaced.. wears out your ring and pinon (I'd guess from the shock of the lash being transmisited) and blow your tranny...happened to me, kind of a pain in the ***.
replace with spring center clutch and its great
'87 924S w/135,000 & '87 951 w/165,000, Both original and both in the process of being replaced.
Which brings up a question. How do you get that plastic shift tube out of the way when you drop the trans?
Oh well, it's up there. Maybe top 10.
Mine has 130k, but I was going more by age of the car. Mileage is an independent variable, but time affects all cars.
