Uh-oh - broke coil lug....
Changing the plugs and wires today on my '84. Decided to start with the coil-to-distributor wire. Popped right off on the distributor end, but required BIG force on the coil end. Had to use pliers,...I know, I know, but I wasn't worried about destroying the wire since it was being replaced anyway. Well, when it finally came off, the terminal from the center of the coil came with it. It plugged right back in, but I'm afraid of it. Do I need to replace the coil? Can I test it without fear of damaging anything else?
Addic
if it doesnt start, good chance thats the problem, if you need one, i have my old one i removed Dont know if it works, because there was an aftermarket one installed, i bought new because of impulse buying, so i have an old OEM bosch one that might work, and an aftermarket one that i know works (big square blue thing)
Update - put the terminal back in the coil, connected the wire to the coil and distributor and .... started right up. Whew. Gonna go ahead and buy a new coil anyway, just to be sure. Some random thoughts: As I've read elsewhere on this forum, the boots on Magnacore wires on the plug end are a less than perfect fit (don't seal as well around the plug hole as the OEM's do); car definitely runs better (smoother) with new plugs and wires; kinda disappointed in the response to the post (thanks, Andrew) - weekend? nobody else encountered this problem? not (yet) a member?
If you put the post back in, see how hard it is to pull back out again. If it still requires significant force, it was probably just a press-fit to begin with, and it's perfectly fine.
If it comes out easily, then you should replace the coil. They are only ~$40 for a new one, which is much cheaper than plug wires
