Two oil related problems...
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
These might be connected in some way, or completely independent. My car is a 1990 944 S2.
First, I've noticed that recently I get the oil pressure warning indicator light staying on with the [!] general warning upon start-up. It only happens if I don't park on a level surface. If I park on the flat, all fine. If I start up after parking on even a fairly minor slope, it may show up. I get the impression it's getting more sensitive to the slope... it used to be only a problem on fairly steep grades, now it seems parking on even a fairly minor grade will set this off.
FWIW, the oil pressure gauge during driving is showing 5 bar, 3 at idle when warm, which it has always done. Oil level is OK. Mobil 1, with about 6000 miles on it and the filter (it's about time for a change).
Second issue: Looking under the car today, I noticed evidence of some sort of engine oil leak... quite a film of oil on the fins of the oil sump, for example, and some oil was coating the aluminium A-arm on the left side. I've cleaned it off with some brake cleaner, but my questions are:
What the likeliest cause of either problem? Could they be related in any way?
TIA for any advice.
-Mark
TIA for any advice.
-Mark
I would assume, (and keep in mind what happens when you assume), sounds like it is the near the oil cooler. Unless the A-arm is driver side. Also, minor leak, you have a bit less oil therefore when you park on a slope, you have lesss oil, hence the light. The only problem i see in my second assumption is your pressures are good. But you can be missing half a quart and have great pressure. Just my thoughts. Good luck.
