930S wheel / hub question - 1986 951
Thanks Scott, Im still doing some research. I will keep that in mind that you have one...
Do the airbag cars use a different hub than the 86's?
Is the hub needed have a porsche part #?
Sam, I maybe wasn't clear in the PM. The airbag cars have 2 splines on the steering column (I'm not sure if non-airbag cars are like this) The 1st spline (smaller) is where the steering wheel should ride. However, the farther back spline (larger diameter) fits the 930S hub, and presumably other 911 hubs. The larger spline is where the stock turn signal cancelation tab and horn contact mechanism are on airbag cars.
I forgot that AJ-USA has the hub adapter available.
Well, Im trying to figure out if the adapter they sell is basically a momo unit or an actual porsche adapter made for the 930 wheel. Anyone know how the 930 style wheels bolt to the hub adapter? (style: 3 holes, 6 holes, etc...) I have a momo non airbag hub adapter already and if thats what they sell then I just need the actual steering wheel.
Thank you...
Thank you...
I'm pretty sure its not a MOMO item, and is manufactured specifically for Porsche by an OEM manufacturer, altho the one I have doesn't have a Porsche part number on it. I'd bite th ebullet and buy the adapter with the wheel, less drama that way.
Regards,
Regards,
Yeah- thats an option but Im not going to be buying the wheel through them so before I buy just their hub I would like to know I need it. I have heard that the 930 wheels will bolt up to a momo hub from more than one person...just trying to get some feedback from people who have actually installed them onto the hub to see how it mounts. Not much in the archives.
Thanks all.
Thanks all.
