Will fuel injectors from any other 944 work in
I have a 87 944 2.5 will fuel injectors from a 944s,944 s2, 944 turbo work in my 87 944 And what years if any will fit my 87' 9
44
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Try swapping the injectors from two cylinders to see if the problem moves. If the problem moves to the new cylinder, then the injector is bad. If the same cylinder is still dead, then it's not the injector (although could be the harness still).
44
Hummm.........well, look here...........and you tell me what YOU think.
http://www.clarks-garage.com/shop-manual/fuel-12.htm
YOUR choice, and experiment.............your call.
