2 stupid questions
2 stupid questions
1) Is there any other place I could find the exterior color code aside from next to the fuse box. Mine is faded completely away. And I need to buy a dash cover.
2) Anyone know what kind of bolts go into the door check (the part on the door not on the body) my car seems to have misplaced them... LOL. Now I know why the doors dont stay open.
Thanks!
Thanks!
1) On the very back panel of the car, looking from inside the hatch, under the carpet, next to the spare tire is a data tag that includes all the options too.
2) I have no idea, my doors don't like to stay open either, maybe I should adjust this.
The bolts are 6mm allen head. It is likely that at least one of the bolts pulled
through the metal and is still in the holder. If that is the case you will have to build a doubler to reinforce the metal where the bolts hold the door holder to the door.
Just check to make sure you have bolts.... LOL. I have new door checks sitting next to me, I could bolt them into the body but fat lot of good that will do. Other than just looking much better. Thanks for the info AR10. Ill check everything out better when I put in the new checks.
Ok I looked in the back, and it says LA1Y/LA1Y.... next to where it says paint co/ Interior
But the second code isn't an interior color code. And the exterior (was originally) kalahari beige.
The interior looks to be a reddish color on the carpet, and the leather and dash, and the roof etc... look to be brown.
If i were to order a coverlay cover would it be safe to assume that it is brown? Or is it hard to tell if it were burgundy or something.
