Spark will get spark half time Help 87' 944
Engine turns over. has fuel. New coil, new wires, new plugs, New cap and button. Removed spark plugs to check for spark.Then i got into the DME box checked for good seating in port 1 looked good.it will crank it will start 10 different times in a roll, then it will crank and not start 10 times in roll. for some reason mine is getting spark then it just loses it's spark I'm not sure why? or it will just start every other time. like here is an example of what happened. Last night it went to start it it just turned over and over tried it twice then as usual smelled gas then just quit after two tries.i went on home. Got up this morning went up to my parents house where the cars is located at it turned over started almost immediately. So i let it run for a minute. then had to leave i came back about 8 hours later it just turned over and over tried it two or three times then just came back home here is my number if anyone would have any tips or thoughts or questions 606-524-2287 name is Josh
