Short in my fuel and oil gauge 87' 944
87' 944 standard OK i have a short in my oil and fuel gauge. i have checked my two grounds running from my battery they are very tight. my volt/battery gauge and my temp gauge seems to be working fine is there another ground for the gauges.
The connectors for the dash are behind the dash. You have to pull off the steering wheel, trim around the dash, and then the dash can come out. If I recall correctly, there are two connectors leading to the dash (they're decently sized). You can either clean them with a little alcohol or a light going over with high grit sandpaper.
