TSB and Recall notice for fuel line
I've searched threads trying to find the identification numbers for the TSB and recall notice for the small fuel line that causes engine fires. Seems the local Porsche dealer can't find the documentation for me and I understand that this is a freebie the first time. Thanks.
Hates Family Guy
The NHTSA recall number was 90V061000, I believe it only affected 85.5 - 88 944, turbo, 944s, 924s
There's a bunch of places on the web where you can type in your VIN and see recalls that affect your car.
Agent Orange
Here it is, from NHTSA:
Make : PORSCHE Model : 944 TURBO Year : 1986
Manufacturer : PORSCHE CARS N.A. INC.
NHTSA CAMPAIGN ID Number : 90V061000 Recall Date : MAR 30, 1990
Component: FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM:FUEL RAIL
Potential Number Of Units Affected : 53427
Summary:
THE HOSE MATERIAL USED IN THE SHORT SECTION OF THE HIGH PRESSURE FUEL LINE HOSE, BETWEEN THE FUEL RAIL AND FUEL PRESSURE REGULATOR, IS SUBJECT TO HARDENING, AND COULD CAUSE FUEL LEAKS BETWEEN THE HOSE AND THE METAL PIPE FITTINGS.
Consequence:
FUEL LEAKS COULD IGNITE ON THE HOT EXHAUST SYSTEM, OR ANY OTHER SOURCE OF IGNITION, RESULTING IN AN ENGINE COMPARTMENT FIRE.
Remedy:
REPLACE FUEL LINE HOSE WITH HOSES MADE OF IMPROVED MATERIAL.
Notes:
SYSTEM: FUEL LINE. VEHICLE DESCRIPTION: PASSENGER VEHICLE.
Summary:
Consequence:
Remedy:
Notes:
porsche sells a kit for it, its just enough to reach in your wheelhouse, you have to remove your liner and do it in there, i did mine when i first bought it, found it was smelling about the 2nd week i had it. there is a real neat compression fitting that goes with it too, any good dealer would know what you were talking about when you call.
