Dash Warning Lights on w/ key off
Car sat in the garage for a couple of weeks and the battery went dead which is unusual as battery will stay charged all winter in storage.
Removed the battery for re charge, re installed and now w/o the key in the ignition all of the dash warning lights are on and the key chime is ringing.
Any ideas to solve will be appreciated.
J Lorenz
'87 944 S
J Lorenz
'87 944 S
Nerd Herder
My .02 worth.. sounds like the the ignition lock cylinder is in the #1 position instead of "OFF"
As the lock cylinders / ignition ages they get a little sloppy. Put the key in and turn the car off- then remove the key- see if this helps.
