Rear seat delete begun-not the usual method
Hmmm. I had heard that they were glued in and that was a pain. I will begin my planning then. I think that removing and adding the carpet mod could be very reversible then..if I wanted to go back to stock. Thanks Fellas
Hey Man
Hey Man
Just an update with Pics
Thought I would toss a few pics out there. I'm about 3/4 finished on this. It took much longer than expected trying to fit everything up to those strange curves. I have been able to install it without drilling a single hole using only 4 existing tapped holes. All I have left is slap the carpet on and mount the amps. Any way i thought I would do an update as I stated 3 weeks ago!
Upper/lower seat stripped of all upholstery before using xylene to remove the old glue
Layout for face piece
Test mounting amps with added bottom section to seat back
Brushed aluminum panels for cooling
Double foil faced insulation under all carpet and bracket mounted to seat belt holes
Upper tray for camera
Gluing Nuprene on the facing under carpet and ever present beer
Side mounts using existing trim holes
Ready for carpet
Ready for carpet
Hey Man
Originally Posted by Andial951
Looks like its coming along well Steve. Good job. When can you come over and do mine?
Legend Killer
Is it absolutely necessary to delete the rear seats? Could you make something similar without removing them? Just in case you wanted to take it out later to sell or if you change your mind.
Hey Man
Originally Posted by Camaro_Muncher
Ive been thinking of doing this, anyone done it with fiberglass? Seems like it would be pretty easy to do and light.
Hey Man
Under the Radar
Originally Posted by KuHL 951
]The rear seats are useless anyway and I got tired of my camera always falling off the seat on runs.
