Problem installing oil pump sleeve.
I'm trying to install the new crank sleeve that drives the oil pump. I can't seem to get it to slide all the way in. It will go in most of the way but is about 1/2" short. I don't think the teeth are engaging the oil pump as I can turn it by hand (or is this normal?). I keep trying to turn as I'm pushing it in in order to make sure it's in all the way but it won't go any farther. I know it's a problem as there is not enough room on the crank to installe the belt pulleys.
Any ideas?
Any ideas?
