89 Turbo parts on 86 Turbo Block
Will an 89 Turbo S housing fit on a 86 turbo block?
How about an 89 cylinder head, will that fit on an 86 turbo block?
Will a 86 turbo block bolt up to an 89 trasmission?
Thanks!
Thanks!
Everything is the same. The turbo will bolt on with no problems. Every block from 85.5+ is identical other than the internals of the n/a versus turbo. The n/a block can be used in a turbo with absolutely no problems along with the head, turbo, intake manifold, and everything else under the hood.
There is no difference in the block between an 86 to an 91 951 - except that the 87+ blocks have the timing belt "automatic" tensioner studs tapped out and installed.
Hell, there are at best minor differences between the NA and the turbo blocks, and the 87+ blocks are identical for all of the 2.5l 944s.
Dal.
Dal.
