Ball Joints... While I'm in there.
Hi. I just bought the geometry correction balljoint kit from Rennbay. Anyone have any suggestions as to what else I should do while I'm in there? Bushings etc. I have 18" wheels. Should I get the 968 caster blocks. Any good place to get them? Anyone feel the 968 blocks are necessary or not? Thanks!
Porsche has a service bulletin that says you must run 968 caster-blocks with 17-inch wheels. May consider changing the front control arm bushing, though its a pain in the *** to do unless you choose an option like having Rennbay rebuild the ball joint for you. You may also consider changing the sway bar bushings while you have it off.
