quicky please help!!!
1) is the 84 944 a hard line front or NOT a hard line front (with regards to the brake lines)
2) are the standard 944 lines rubber? i.e. will i notice a big difference in brake pedal feel?
3) does the "set of 4" brake lines change the entire system? or just a few parts?
in other words, is this replacement worth it?
944 lines are rubber until near the caliper I believe. They are on all cars, at least without solid axles, because otherwise the lines would break when suspension moves. You can't replace all the rubber lines with metal.
Where is this set of 4 you are looking at?
I think he might be talking about these stainless brake hoses from Pelican:
http://www.pelicanparts.com/cgi-bin/...ber=PEL-RP6944
those would work too....basically, im just wondering if its worth the work to put them in. i don't think my brake lines have ever been changed since my father (original owner) got it back in 84
