getting wiper motor out ?
I am getting ready to replace my front wiper motor (finally found one) Once I remove all of the bolts from the wiper assembly I cannot get the unit out past the blower assembly. Do I need to remove this? Is there some trick to getting this out? If I need to remove the blower assembly can anyone offer some instruction on this? Any help is greatly appreciated.
Mark / 1986 944 NA
Mark / 1986 944 NA
There's 6 or 8 bolts. One or two wiring harnesses. One vacuum hose underneath when you lift it out. It came right out for me. You may have to stick a flathead under it to break the seal. It came out easy. A little tricky to put back in. Tight fit.
