Hub Centric Adaptors 50mm/37.5mm
Anyone interested in hub centric aluminum adapters that will convert early offset cars to Club Sports? I have four available, 2 50mm for the rear and 2 37.5mm for the front. They are from Better Bodies in California, T-7075 aircraft aluminum with built-in studs and nuts.
http://www.betterbodiesmotorsport.co...1/spacers.html
They are very nice parts, but I am going back to original offsets for my track/autocross car to save weight and reduce scrub radius in the front. Original idea was the use the same set of R compouds on NA and Turbo S...but the NA is just not happy at the limit with the late offset/spacer combination. Will work fine for street applications, IMO.
